Copy DVD Movie with DVDFab DVD Copy in a Flexible and Simple Way
03/24/2022
A DVD copy software program that can clone or copy the full disc of your DVD may not satisfy your needs all the time. Sometimes you may only want to copy the main movie, customize the content on the DVD, split the content on a DVD 9 to two DVD 5, or merge two DVDs into one DVD. DVDFab DVD Copy comes for your various needs! It provides six copy modes and can copy your DVD to your hard drive to save. DVDFab DVD Copy is easy to use. Now please follow me have a look.
Copy DVD Movie with DVDFab DVD Copy in a Flexible and Simple Way: Step 1> Run DVDFab 12, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes (see Note at the end) to choose. Here I take Customize mode as an example.
Copy DVD Movie with DVDFab DVD Copy in a Flexible and Simple Way: Step 2 > Load the source.
Copy DVD Movie with DVDFab DVD Copy in a Flexible and Simple Way: Step 3 > After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, and do advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
Copy DVD Movie with DVDFab DVD Copy in a Flexible and Simple Way: Step 4 > Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "folder" icon is to save the output as a DVD folder on your hard drive; to select a directory by clicking the "image" icon is to save the output as an ISO image file on your hard drive.
Copy DVD Movie with DVDFab DVD Copy in a Flexible and Simple Way: Step 5 > Click the "Start" button to start the copy process.
Note:
6 modes:
If you choose to save the output to a blank disc, you will be prompted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the cloning process.
For more detailed information about DVDFab DVD Copy, please visit https://www.dvdfab.cn/dvd-copy.htm.
